-7 days from a date (DD/MM/YYYY) written in a text box
Hi I have made my own calendar and on submit it enters the date chosen into a BOX1 in the format of DD/MM/YYYY. I then need it to minus 7 days into BOX2 on text change of BOX1.
I thought I had it but it says invalid date and then aN/aN/aNa
I tried a few combinations on the forum but nothing works :frowning:
Can anyone help? im using Axure 7.0 and cant open 8.0 samples
@InTheWide,
You might want to keep your same basic questions limited to one threadโ€ฆ See my reply to your other thread here. You should be able to easily adjust the numbers to get -7 instead of +14 in the example.
https://forum.axure.com/t/can-anyone-conver-this-rp-file-to-7-0-format/53547/2?u=mbc66
