I set out to post a quick fix for your file …but it turned out it wasn’t so quick and easy! Take a look at this updated file for further explanation.
Table Help.rp (164.9 KB)
I show two solutions. The “Table (1)” page has a straightforward solution to highlight a row on hover, highlight in different color on click, and highlight on selection of checkbox. But, if the repeater is updated/altered in any way, such as adding/editing/deleting a row, the highlight and checkbox status is lost–because the repeater gets rebuilt. The “Table (2)” page has an improved solution to retain this status when the repeater gets updated.
Like @Adolfo said, I placed a rectangle widget (named “rowBg”) in the back of the repeater (actually just in the back of the “Display Group” to make the hover effect easier) I assigned its “interaction style” of “MouseOver Style” to a light blue color ensured the group’s “Fire Mouse Style Effects” option was checked on–thus the hover highlight happens automatically.
I created a “Selected Style” for “rowBg” with a darker blue color. Then added a Click or Tap event to “Display Group” to “Set Selected/Checked of rowBg to toggle” (or Update Row in the improved version.) I added a conditional case of “If is selected of CheckARecord equals false” so it would not conflict with the highlight due to a checked row.
Here is where I ran into a problem. The checkbox (“CheckARecord”) is inside the “Display Group” group, and clicking it fired two events: it changed its own selection state and set the selection state of “rowBg” to match. But, it also fired the group’s Click or Tap event --which essentially “double toggled” “rowBg”. My fix for this was to place a hotspot over the checkbox and use the hotspot to toggle the selection state of the checkbox. Clicking the hotspot does not fire the group’s Click or Tap.
