Accordion inside a repeater - not resizing correctly
Hi, new to the forum and pretty new to Axure. I’m trying to create an FAQ that consists of a repeater with accoridons inside of it to show/hide the answers. See attached. The problem is that when showing the dynamic panel with the answer inside, it is either not resizing itself properly or not pushing/pulling the other widgets properly. Or more likely I am doing something wrong. Any pointers would be appreciated.
repeater_accordion.rp (90.7 KB)
Hi Tomin,
There’s no auto-fit feature for text on Axure (or I didn’t find it).
So the height of your content was either too big or too little in regards with its default height.
With a bit of math:
  • 100 words matches 1 line
  • 1 line’s height matches 16 px
you can resize your text with the approximation: height = lenght / 100 x 16
Here the result:
repeater_accordion_V2.rp (91.3 KB)
Beware if you change the width of the text, you will need to change the “100 words for a line” value
Best,
