I am creating an accordion menu and need to animate expanding and collapsing transition, the problem is the widgets that are being pushed down when the menu above is expanding are out of sync when it animates this is due to the toggle automatically applying an ease in/out transition. Is there anyway to bring them into sync?
Accordion - push/pull & toggle out of sync
Richtux
#1
mbc66
#2
You might need to post your .rp file so others can see just what is going on and better help you.
How are you accomplishing your expand/collapse? Changing dynamic panel states, filtering a repeater list, or something else? Not clear what you mean by “out of sync”… In general, you can animate the push/pull, and try to match that to the animation you use to expand/collapse your accordion. Maybe try adding a Wait statement before or after your transition to get it to “sync” better with the widget push/pull.
