Adaptive prototype doesn't preview correctly in a browser AX9
Hi there,
I opened an existing RP8 file in AX9. It converted correctly. But when I preview it in a browser or publish it the adaptive views do not show the correct UI as I created in AX9.
Within Axure 9:
Within browser (Chrome)
Even when I scale the browser it does not change the adaptive views (setting is ‘auto’).
Any suggestions?
Hi Jeranimo,
That’s no good! Could you post your Axure RP 8 file here for me to take a closer look?
[details=Summary]DekaMarkt_Web_20180917_v0.6.rp (4.4 MB)
[/details]
Hi Jeranimo,
Thanks for the .rp file! I’ve been digging through it on my end, and it looks like the 9 beta doesn’t like when you have an unplaced dynamic panel in a master in a non-Base adaptive view. Having this setup will break the adaptive view functionality in the browser output, and I’ve filed this as a bug with our QA/dev team to get fixed.
@Jane_Axure Can you confirm the issue is about masters and adaptive view.
Whether the components are within a dynamic panel or not is irrelevant for this bug, right?
I’m trying to confirm this is the same bug as the one I described there: Adaptive view not rendering properly in browser when using a master
Hi supertoket,
The issue you’re running into isn’t the same as the one Jeranimo ran into in this forum thread, and you can find my response here. :slight_smile:
