Unless there is code that sets the values of widgets in the repeater row, each row will default to the state it was authored in. And when any change is made to the repeater (add row, update row, filter, etc.), the entire repeater redraws from scratch, setting each row to its authored state, which in your case is an empty dropdown.
The Item Loaded event is triggered just before each row draws, allowing you to make changes to each row through code before the row displays.
So what you’ll need to do is this:
- When the user chooses from the dropdown, you’ll want to write that choice to a column in the repeater.
- In Item Loaded, you will set the dropdown to that saved value
It definitely feels more complicated than it should be, especially since you need to use a local variable for something as simple as this.
This article may help in understanding how best to deal with the repeater.
I’ve updated your file as an example.
Add Object Dynamically.rp (49.3 KB)
[Edit] By the way, once you have this set up, it’s easy to make a new row show up with the dropdown preset to whichever value you want. Just set the column I referenced above to the desired value in the Add Row command.
