Adding a timer to repeater rows
I have a repeater with x numbers of rows. Each row represents a different timer and I would like each timer to be started, paused, reset independently.
Starting the first timer doesn’t seem to be an issue. However, when I start a second timer, the first time briefly displays as “00:00:00” before showing the correct time.
When I pause a timer, all existing timers briefly display as “00:00:00” before showing the correct time and the paused timer shows as “00:00:00” where it should display the paused timer value. When the timer resumes, it does not appear to resume from the paused time.
Any help would be much appreciated. See attached file.
Thanks, Caroline
repeaterTimers.rp (68.3 KB)
