Adding columns to repeater
with placing a repeater I got s single column with 3 rows (see https://docs.axure.com/axure-rp/widgets/repeaters/).
How to add further columns to the repeater ( adding data is no problem) ?
Thanks ,
Michel
select the repeater and move the element onto the repeater space.
Cheers,
Michel
You can also select the repeater, open it, go to style tab, and set to “horizontal” view.
Of course you could add a new widget to the existing row by placing the new widget (rectangle, text field, image … what ever you wish) to the right of the widget provided in the sample repeater for row1. Give it a name, and make sure to map it in interactions. Now in the data sheet you can add a new column, provide data, and in interactions remember to map everything.
