Adding notes to cases
I have created 2 cases for a button. Now when i click on a case the cases appear in form of two buttons 1 below the other. Is there a way of adding a note in that same section where the two buttons appear.
Hi rahulzlpr,
It sounds like when you click your button widget, a popup appears that allows you to select between the widget’s different cases–is this right? This happens when there are multiple cases on a single widget that do not have any conditions to differentiate between them:
There isn’t a way to add additional notes to this popup, but I’ll go ahead and submit a feature request for this to our product team. In the meantime, you can try adding a note through the button’s “Notes” tab in Axure RP with details about the different cases, which might help.
Let me know if you have any questions!
