Align -> Right <- for elements/group
Hello, everybody,
how can I place a group or several elements on the right side at each resolution?
It should be on the right side regardless of the resolution (as far as possible).
regards
Hi Max1,
You could do this by encompassing the group of elements on the right side into a Dynamic Panel (right-click > “Convert to Dynamic Panel”) and then using the DP’s “Pin to Browser” option:
Once you click on this setting, a dialog will appear allowing you to choose the horizontal and vertical pin you would want your dynamic panel to be placed at all times in the browser. Since it sounds like you want to pin the group to the right side, you would choose the “Right” option for the Horizontal Pin:
And that should do it!
PintoRight.rp (54.3 KB)
