Aligning separate items to text within Axure is fine but when it renders in the browser, the items do not appear in the same position. Bullet points are also terrible in Axure, I wish this function worked better. See the attached image rendered in the browser. How to fix this??
I did switch over to using a table but I find this alignment problem is often an issue with text areas/fields and bullets.
