following the topic written here
Here is the issue:
For some time, I created and stored in my library a material-design-alike field, and used this component in several prototypes.
it worked correctly on several previous versions, the expected behavior is that on click, the field label moves up, and on lost focus (if there was no input) the label moves back down.
In your last previous version (I can’t remember it’s number, but you released it 2-3 weeks ago), the label wrongly kept moving down on preview, but it worked correctly on publish, so I didn’t bothered you about it, but on this 9.0.0.3665 version it fails also on publish, so my developers can see it
I need your help.
Thanks
Eran.
File attached:
Single field For Axure forums.rp (49.4 KB)
