Hi All,
I have created animation using 66 effects. Please check the demoand give me some feedback.
I hope it will be useful for all.
Thanks and Regard,
Vikram
Hi All,
Thanks and Regard,
Vikram
Thatâs a really good library. I think the only thing I would (personally) change is to combine the rotate in/out with zoom at the same time.
Regardless of that though, awesome work Vikram.
Thank you very much for your feedback. Now i am trying to implement animation using different scenarios in axure.
I will post my rp file very shortly.
Awesome work indeed! Looking forward to dissecting the .rp
I am curious to which JS framework you usedâŚ
Hi All,
I have created multiple animation effects run on single click.
Please check the below thread.
One click executes multiple animation effects
Hi All,
Hi All,
Here i have posted two types of rp file.(select and multi select).
Create a plug-in in AxShare and select End of the Head.
Just insert a below codes
<link rel=âstylesheetâ href=âhttp://daneden.github.io/animate.css/animate.min.cssâ />
<script type=âtext/javascriptâ>
function testAnim(x) {
$(âdiv[data-label=âanim_boxâ]â).removeClass().addClass(x + â animatedâ).one(âwebkitAnimationEnd mozAnimationEnd MSAnimationEnd oanimationend animationendâ, function () {
$(this).removeClass();
$(document).ready(function () {
$('input[value="Animate"]').click(function (e) {
e.preventDefault();
var anim = $('div[data-label="anim_opt"] select').val();
testAnim(anim);
$('div[data-label="anim_opt"] select').change(function () {
var anim = $(this).val();
testAnim(anim);
</script>
Just insert a below codes.
var res;
var i = 0;
$(âinput[value=âAnimateâ]â).click(function (e) {
res = "";
i = 0;
e.preventDefault();
var anim = $('div[data-label="anim_opt"] select').val().toString();
res = anim.split(",");
var myVar = setInterval(function () { setTimeoutTest() }, 1200);
function setTimeoutTest() {
testAnim(res[i]);
i = parseInt(i) + 1;
</script>
Thanks
animate_multiple_rnd.rp (56.9 KB)
animate_single_rnd .rp (56.4 KB)
Hello Vikram and thank you for your awesome work.
Iâve managed to add the plugin to test the transitions from a local rp file (the one youâve just shared).
Still, iâm unclear on how i can use them (the animation). Am i supposed to find them when i want to add an interaction in Axure ?
Thank you for your answer,
Cheers,
Hi!!
I have the same problem, I donât know how to use this in my own files. What Iâd like to do is to have an impor animation (import orders in an ecommerce for instance), so when the import ends up, it automatically fades out with a bounce out effect. Is it possible?
Thanks in advances, and congratulations for your work Vikram!!. Itâs just awesome.
Hi DavidSp,
Thanks once again for your feedback!
I have created multiple animation effects run on page load event.
Please check the demohere.
Note:
Open the attached RP file and select the what are types of animation do you want and set hidden (for example, I have set hidden for animation button).
Just insert a below code.
$(function () {
$(âinput[value=âAnimateâ]â).click();
var res;
var i = 0;
alert(onpage load animation test);
res = ââ;
i = 0;
e.preventDefault();
testAnim(res[i]);
</script>
Thanks,
Vikram
animate_pageload_rnd.rp (56.7 KB)
[QUOTE=Sacha V;42171]Ok donât worry about it. Iâve managed to re-use it
Thanks[/QUOTE]
Hi Sacha,
You mind sharing your RP file to see how you did it?
Hereâs mine:
Untitled Document
Attached is the RP file.
Iâve already done the plugin but now Iâm trying to animate the checkmark. Animate=pulse
Feel free to chime in too @Vikramadhithan
animate_single_rnd_VT.rp (75.8 KB)
It doesnât work for me. Axure made a change to default projects to HTTPS and the file location referenced for the stylesheet is http:// so the request is blocked. If you were to follow the instructions and reference HTTPS I think it would work, although since this is post is from a while back the files are Axure 7 files.
