Are there resizing constraints in axure?
In Sketch and other software (Affinity Designer, Pencil Project) there is a feature called “Resizing Constraints” allowing you to specify how a element will resize in another. Is there anything like this in axure?
Hi Daveman,
Hmm, that’s pretty nifty but isn’t something that Axure RP has. The closest thing that I can see available in the current UI is the “Fit to Text Width” option for individual widgets; if you were to put a bit of text into the white rectangle (just enough to fit its width), set it it to “Fit to Text Width” and then resize both widgets, the white rectangle should maintain its width while everything else gets resized. Hopefully that helps a bit!
