Hello all,
I am attempting to create a timeline using a repeater, with the repeater containing instances of symbols that represent individual points on the timeline.
The issue I’m having is getting points on the timeline to appear in the desired location across the timeline, using an item in the repeater called “Item.Timestamp” to represent the point in time (seconds) for that symbol. Essentially, I want the Timestamp item to be how far along the timeline the symbol appears. I’ve been using the interaction:
OnItemLoad
Move Symbol to [[Item.Timestamp - Target.width]]
To get each symbol to move horizontally to 4 seconds, 8 seconds, etc. - which is represented by the Timestamp item. However, Axure seems to interpret the coordinates “0,0” as starting in a different place for each item in the repeater, so their positioning is off.
I realize this might be a bit difficult to follow, so I’ve attached the file below:
Timeline_Repeater.rp (99.8 KB)
Thanks for any help, advice, or suggestions!
