Hi wjh!
Hmm, are you seeing that icons on Axure Share are missing only in the current file that you’re working on, or are you also seeing them missing if you check existing published projects or publish a new test file? I’ve tested on our end with new files (both .rp files and team projects) and it looks like everything is working normally on our side. If you’re seeing that all of your files are showing the same behavior in the browser, then please verify whether switching browsers or refreshing the cache helps.
If it still sticks around, please try right-clicking the browser page, choosing “Inspect/Inspect Element” from the context menu, and then clicking “Console” in the window that opens; in that window, if you see any errors in red then please take a screenshot so that we can take a look. This would help to see if perhaps something is blocking images from loading on your end.
Also just to verify, do other users on your end (ideally on the same network) see the same issue? This would help to confirm if perhaps something on your network changed that is blocking certain elements from loading.
If just one specific file is failing to load, then would it be possible for you to email the exported .rp file from your team project (“File > Export Team Project to File”) along with the published team project’s Axure Share ID over to support@axure.com so that we can take a look and assist? Thank you!
