Axure 8 incorrectly renders an Icon-Font I created. Actually the font bleeds, i.e. an outline is put around the font, see below:
Axure 7 correctly renders the Icons.
Now if I import this Axure7-file into Axure 8, then also Axure 8 renders those icons correctly. The problem is, that if I add a character in Axure 8, then it starts to bleed again. The worst is, if I touch those correctly rendering icons, then they start rendering incorrectly.
You can see this most clearly in test-axure8.rp by comparing the design section with the section displaying the icons as per screenshots above.
