I wonder if anybody can please help.
I love Axure 8, but when ever I go to open Axure 8 it will not open.
I have found a workaround, which is to navigate to the folder C:\Users%USERNAME%\AppData\Local\Axure and then delete the settings.bin file in the folder.
This will then work, until I close down Axure, and then if I want to open it again next time then I need to follow the same process and delete the settings.bin file in the above folder.
Does anybody else have this issue, and is there a fix or workaround ?
I am using Windows 7 SP1 Enterprise 64bit, in case this helps. The version of Axure is 8.0.0.3297
Thanks for your time !
