Axure 9 Beta Connect Show exceptions
Is this axure’s biggest criticism of all time? Wouldn’t it be embarrassing if you couldn’t connect line?
Screenshot:
I would like to make a suggestion, I have to convert the link to a picture after the normal display, it is recommended to preview the direct conversion to the picture format
There will be a fix for connector routing in the next build of the RP 9 beta, which we expect within the next day. In the meantime, you can switch your connectors to another path type (other than rounded corners) and they should render as expected in the browser.
The new version is already installed and the problem is now resolved
