I have a model which the user can switch between three graphic themes and am having trouble with one element that is common to two of the three, and different in the third.
Here is the scenario…
In theme one and two the image is shown, while in theme 3 a different version of the image is shown.
To make this work I’m using a button group that shows and hides the items appropriately for each theme.
The trouble I’m running into is that 2 or 3 theme changes in theme 3 stops hiding the item it’s supposed to hide. In the initial run through it works fine - it seems to be ignoring the hide command once the theme has been changed a couple times…
Apologies for not including a sample of the actual file, but the work is client confidential. The attached file is scripted the same way as my client file, but (annoyingly) doesn’t have the same issue… Is there a reason why Axure would just start ignoring a hide command?
puzzling…
-Evan
3 theme hider_sample file.rp (56.7 KB)
