Axure pull/pull inside repeater, footer content below it. how to move footer along with the push/pull ?Untitled.rp (61.1 KB)
Axure pull/pull inside repeater, footer content below it. how to move footer along with the push/pull?
Instead of using push/pull in the repeater case:
Right-click the repeater and choose Convert to Dynamic Panel (or, place the repeater in a dynamic panel and make sure the panel is set to “Fit to Content”). Note that the footer should be outside of this panel
Add the following to this dynamic panel
OnResize move footer to [[This.left]] , [[This.bottom]]
This works because the “Fit to Content” panel resizes to fit the changing size of the repeater, and when it resizes, it gets the OnResize event.
thanks @josephxbrick !
i can’t get rid of the push/pull, i need that functionality though. So how do you mean to accomplish the same push pull behaviour without using push/pull? Btw I tried to do what you said, it doesn’t work well. Untitled.rp (57.3 KB)
You need to use Move to [[This.left]], [[This.bottom]], not Move by [[This.left]], [[This.right]]. If you want to have, say, 10px spacing between the repeater and the footer, you would say Move to [[This.left]], [[This.bottom + 10]]
Attaching file: Untitled (1).rp (56.0 KB)
Repeaters automatically expand a row to accommodate the changing height of its content, so specifying push/pull on the dynamic panel in the row isn’t necessary (unless there were something in the same row that needed to be pushed down).
