Axure Repeater Filter Between
I can figure out the basic filters, but I don’t see a Between option.
I have a simple column called “Years” and I want to be able to use a UI Range with a min and max, and show the years equal to and between.
Thanks.
-g
…I should also note that I have other columns with much more complex numbers, ranging from 1.55 to 783.55 - so the “between” portion can’t be as simple as creating a list of years.
Thanks.
-g
This requires some syntax knowledge, but it’s not too bad. This ought to do the trick for you:
[[Item.number >= min && Item.number <= max]]
where ‘number’ is the name of the repeater column containing your values, and ‘min’ and ‘max’ are the values you’ve chosen in your range picker ui.
Example: filter-between-values.rp (54.8 KB)
