Can I change the default scale when launching Axure Share projects? Default is ‘Original size (100%)’. Would like to assign default to ‘Scale to fit’ width.
Axure Share: Default Scale?
Alyssa_Axure
#2
Hi! It doesn’t look like there’s a setting for changing the scaling of a project from within Axure RP, but if you want to share the published URL with others and have that link launch the prototype with “Scale to Width” selected, then you can first open the prototype URL on your machine and select “Scale to Width” in the player settings; this should update the format of the URL for the project (adding “&sc=1” to the end), and copying and sharing the URL in that state should load the prototype with “Scale to Width” selected in the player. Hopefully that helps!
system
closed
#3
