Axure8预览不了,所有浏览器都试了,全部显示一个内容
Hi! It sounds like you’re unable to preview your files in all browsers. In order for Axure RP to preview, it must be able to access the localhost at 127.0.0.1. Do you happen to have a proxy enabled, or any other security tools that may be interfering with Axure RP’s ability to generate a preview on the localhost? If so, then we would advise checking your settings and allowing access to 127.0.0.1 to allow preview. In the meantime, if the issue only affects preview then you should be able to use “Publish > Generate HTML Files” as a workaround to view those files locally. Hopefully that helps!
