Resizing Axure windows is difficult in Windows operating systems when maximization is not required. When the cursor is placed at the edge of a window in regular Windows software, there is about 3px of hotspace that triggers a width or height adjustment, whereas when the cursor is placed at the edge of an Axure window, there is only 1px that triggers such an adjustment. The difficulty is compounded by the fact that if the cursor is moved to the 4 corners of the window in order to directly resize the window (i.e., to adjust the width and height at the same time), the mouse has to find the 1px by 1px point, which is very difficult and can sometimes take close to 10 seconds to find.
Translated with DeepL.com (free version)
在Windows操作系统中,当不需要最大化时,Axure窗口的大小调整是比较困难的。当光标放在常规Windows软件的窗口边缘时,大概有3px的热区会触发宽度或高度调整,而当光标放在Axure的窗口边缘时,只有1px可以触发这种调整。雪上加霜之处在于:如果光标移动到窗口的4个角落以便直接调整窗口尺寸(也就是同时调整宽度和高度)时,鼠标必须找到1px乘1px的那个点,这非常困难,有时需要将近10秒才能找到。
