question 1:
For example, when I change the size of a component and move the component to the right of it, does the component to be moved need to be spaced from the component to be changed? Problems occur when the spacing is 0.
Here are the cases with and without spacing:
Zero distance
Allow 1px distance
question 2:
cannot switch back to the width change of This after changing the Move distance to custom
We’re trying to recreate the interaction setup you’re describing and reproduce the behavior that you’re seeing. However, our Move “All widgets to the right of This” is behaving correctly even at zero distance. Here’s an example file on our end just in case:
Can you attach your project file so we can test it on our end?
For your second issue, we’re able to reproduce this and can confirm it’s a bug. I’ll go ahead and file this for our QA team to investigate and resolve in future RP 11 builds. Thanks for bringing this one to our attention!
