SET TEXT can use the SUBSTR function normally during CLICK OR TAP interaction.
Copying it to ITEM LOADED will not work.
Why can’t I use the SUBSTR function on the ITEM LOADED interaction.rp (54.3 KB)
Weird. Playing around with it, it seems like the problem is somehow with concat(). I also couldn’t get toString() to work on any value consisting solely of numerical digits, no matter what I tried. I got it to work the way you probably wanted by adding an alphabetic character to the beginning of “0000” and using the + operator instead of concat(). Definitely buggy.
pad-hex-values.rp (52.1 KB)
