[Bug] Tooltips in Beta v.9.0.3657
OS: macOS 10.14.5 (18F132)
THE ISSUE
  1. Add a Tooltip to an element A in your design. Save the file and close Axure.
  2. Reopen the same file. Select the same element A, check if the Tooltip is still there: it’s gone from the input field.
  3. Select another element B and add a tootip to it.
  4. Now select yet another element (C, without a tooltip) and open the panel to add a tooltip. You see the tooltip text from the previous element B is already there.
SUPPOSED BEHAVIOUR from Stable v.9.0.3655
  2. Reopen the same file. Select the same element A, check if the Tooltip is still there — yes, here it is.
  4. Now select yet another element (C, without a tooltip) and open the panel to add a tooltip. The Tooltip field is empty.
Hi, thanks for reporting this! It looks like the behavior you’ve described matches a bug report that we have filed on our end for build 3657 and are currently investigating. We’d added this thread to that ticket and will be working on a fix. :slight_smile: In the meantime, build 3655 seems to be free of this issue so if needed you can roll back to that build to avoid the bug for now. Thank you!
