Button interaction inside Mouseover not working - RESOLVED!
Hello everyone,
I have created an ‘OnMouseHover’ interaction which is set to show’Dynamic panel’(treat as flyout), but inside the dynamic panel i have a rectangle that i want a click action on.
In the below video URL you will see i have hovered over an area and another layer of text appears(dynamic panel) and within that i have the Edit button, which does not seem to be working:
Can anyone please provide a solution?
Hi bhanu2307,
Could you post a copy of the prototype file you’re currently working with? If your file is a team project, you can export it to a regular RP file by opening it in Axure RP and then going to “File > Export Team Project to File” in the menu.
If you can post a copy of your file, we’ll be able to get a closer look at what might be going on!
Hello Simon,
Thanks for the response. Sure, please see this MockupP2_v0.2 - Copy.rp (124.8 KB)
Let me know if you can fix this issue.
Did you wanted to do something like that?
MockupP2_v0.3.rp (118.6 KB)
If so, I would recommend to use OnMouseEnter and not OnMouseHover to trigger the interaction
Best,
Thanks Everyone for the help!
The solution worked. I am new here so need help in all these tiny mistakes. Thanks for rectifying :slight_smile:
