Yesterday I figured out a way to get certain value from certain row in repeater. I put a hotspot (other widget is the same) in repeater and set a interaction trigged by WIDGET outside the repeater. The interaction is set to output the value from certain row if the condition is OK and then write it in OUTPUT widget. It worked on almost every custom column value, but I found it does not work on the original one ‘item.index’. If I put that logic on like “onMouseClick” and I did click on it, it worked. It seems like ‘item.index’ can not be output from trigged Interaction.
Is it a bug?
