Cannot hide notes on widgets when sharing
I would like to hide widget notes when sharing my prototype. I can see the options in the inspector, but they are all disabled. How do I enable all these options?
These appears to only be disabled for my team project.
Hi dibattista
When working with Team projects, if you want to change any of the parameters in the Generator, you will first need to “Check Out” the Generator by clicking the “Check Out” button in your attached image. Once you have the Generator checked out, you should then be able to un-tick the “Notes” checkboxes as desired.
We have some additional documentation at the link below, should you find that useful:
https://docs.axure.com/axure-rp/reference/working-with-team-projects/#generators
I hope that helps but if you experience any issues please write into us at support@axure.com for further assistance,
Thanks John! I didn’t realize that panel was a separate check in/out to my file.
