Can't see IF/ELSE on interactions
Hi, since today I can not see if my interactions are on if or else, if I toggle it nothing visual happens although it still affects my interactions.
This means some of my interactions are not working because they are on “else” setting but I can not figure out which ones.
Hey @lizaa :slight_smile:
I have sometimes experience, the same thing as you describe, that the interface is stuck and therefor wont show the “if or else”. What i have done, is either press the Reset view or dragging the “window” with the interaction out so it kind reset the view. You can also try clicking the “toggle the If/else” Hope it helps :slight_smile:
