Can't select and move multiple widgets
When I select 2 or more widgets at a time and try to move them it selects the item behind and moves that.
Hi abogatch,
Is there a chance your widgets are in front of a Table widget? If so, there is a known bug we have on file where multiple widget selections cannot be dragged when placed on top of a Table widget, and our teams are working on a fix for the issue. For now, it’ll help to move the widgets one-by-one, which I realize isn’t ideal, but hopefully it helps a bit!
If the widgets are not placed on top of a Table widget, could you share your .rp file here for me to test?
Aha! Yes it was on top of a table. Thanks for the heads up.
