I’m using Axure RP8. I tried to load a library that I think was created in RP9, and nothing loads. But now I can’t remove it… the options to Edit, Refresh or Unload are all disabled. Is there another way I can remove this library? I can obviously just ignore it but if there’s an easy way to remove it, I’d rather do that.
Can't unload library
lgili
#2
I am having the same issue - The Remove library is disable
Did you manage to solve this?
Thanks
kgrotjohn
#3
I did not. I’ve since upgraded to RP9 where I don’t have any problems with the library.
