I’ve haven’t issues trying to view objects in libraries. The default library is ok but if I select Icon library all I see is the label of the icons and not the image of the icons.
Can't view object in libraries
Rachel
#2
Hi zebrow,
Let’s try clearing the library cache and relaunching Axure RP to see if this clears up the issue. To clear the library cache, please locate the “cache3” folder:
On OS X:
/Users/[yourusername]/Documents/Axure User Data/Axure-8-0/cache3
On Windows:
C:\Users%USERNAME%\AppData\Local\Temp\Axure-8-0\cache3
Please delete the contents of the cache3 folder, and then restart the Axure RP app to see if the widget images in the Icons library load again.
Best,
Rachel
