Here it does what you wrote:[quote=“neerajk, post:1, topic:52668”]
on dragging the blue slider, the dynamic panel should move left and right
[/quote]drag-slider-chnage-states_V2.rp (87.8 KB)
But not sure that it does what you expect…
Basically:
Use Ondrag on your blue slider to move itself with DragX: it will move the blue slider with the movement of your mouse but only on horizontal direction
Add boundaries to block blue slider on the right and on the left of the scroll bar
Move the dynamic panel using OnDrag on it: use Target.y so the dynamic panel stay on its y postion, and Target.x-Drag.y so the dynamic goes left when the blue slider goes right
Best,
