Checkboxes in repeater in master not working
Not sure if this is a bug but if I have a checkbox in a repeater within a master template the checkboxes don’t work in Axure RP 9 Beta. I tried the same thing in version 8 and it worked. Help!checkbox_repeater_master.rp (57.8 KB)
Hi Geraint!
Hmm, I’m seeing the same issue on my end as well. I will be filing a bug report regarding this unexpected behavior with our teams. It looks like this issue does not occur when a master is not in use, so one workaround may be to break away the repeater widget from the master for the time being.
Thanks Chelsea you read my mind, that’s what I’ve done in the interim. Thank you.
