I hope everybody is staying safe and well first of all.
I am trying to compare the variance between 22 entries in a repeater against the lowest price row.
So I have a repeater that contains an ‘uplift’ column (a) (which is set using a dropdown within the repeater row and updates row on selection change) as well as unit price info column (b) which is combined with a master unit volume text box outside of the repeater (c) to provide a total price (d) which is set into a text box on load of repeater… so abc=d… c and d are not within the repeater table data. This all works fine.
So the first functionality I am trying to achieve is extract the minimum value of d to make (e).
From there I want to set text of a Variance text box within my repeater that is effectively d-e=(f).
I kind of got it to work but it seemed to mess up somewhat where the row that is e is in the middle of my repeater set, f only seemed to calculate correctly for the rows below it and not above.
Once I have that working, what I then need to do is the third piece of functionality that where a is changed, it needs to compare d again etc etc.
I hope this comes across as semi-coherent - im guessing you can tell I’m still relatively new to Axure Variance Example.rp (53.7 KB)
