Connect Axure to C# Application
Hello,
is there a way to connect the UI I’ve designed in Axure to a C# application? Maybe by using the Axure RP Api?
Thank you!
My understanding of the Axure API is that it was designed to primarily let you read and export from Axure files. So presumably you could build a tool that reads the file and generates a UI from what you’ve designed. I don’t think the API will do it for you, though.
