Copy from Axure - Paste in Outlook - very heavy email
I’m using a MacBook. When i copy a set of widgets and images from Axure, and pasting it to an Outlook email, this email becomes very heavy.
Is there a way to resolve it?
Thanks
Hello,
When you copy and paste widgets from Axure RP into another application, the widgets will paste as images. The dimensions of the total selection will determine how large that pasted image is, so the larger the selection the larger the image in the email will be. If you’d like to control the size of the image prior to including it in the email, then we would recommend using “File > Export [PageName] to Image” to export an image of the page, and then use an image editing tool to resize that image as needed prior to attaching it to your email.
Hopefully that helps!
