I am trying to replicate the case where a user is sent an email 6 digit verification code and copies the number to a field where it is then verified. Quite a common pattern these days.
I have it work under the following cases:
- When someone manually types the number across
- When someone uses ctrl + c then ctrl + v
- when someone uses mouse copy & then crl + v
However during user testing I had a repeated issue… when a user tries to use right click paste (plain text or paste) into the field I see the number slightly greyed out and the value is not recorded/readable from the prototype.
I created this basic example to demonstrate the issue:
copy and paste test.rp (57.7 KB)
I am using the latest version of chrome and have also used the new chromium edge… I haven’t gone as far as trying firefox.
I have however copied the clipboard value to other applications… Am I missing something?
Chrome seems to know it is there… also if I navigate in the field the cursor jumps from the start to finish of the number as if the number is an image.
Axure version 9.0.0.3716
Any help appreciated.
