Hi everyone ! I have just started my first prototype on Axure, I have succeed to do everything I wanted to THANKS to this community ! But now I think I am encountering a problem too difficult to solve on my own. Here it is : I have made a group with different buttons and each one is a dynamic pannel . If you click on it, a modal opens and inside it there is a check list. So, if you select at least one of the elements on it, when you validate the modal, this one closes and the button in the group changes his look. (if you select nothing the button stay the same).
All this is already done, and now is the tricky part :
_ In addition to this change of status, I d’like to add the creation of a tag that is named the same as the text contained in the button (dynamic). I have succeed to create a bloc(empty tag) when you validate the modal but inside there is only the text “validate” (that is also not seen properly) from the CTA. I d’like to change it but I really don’t know howwww.
_ the best would be after I succeed to create those tags to export them to an other page and that they are not seen directly in the same page (just appear in the next one. It isa form)
And because an image worth a 1000 words : tag-creation.rp (358.2 KB)
In this file the button “revetement mur …” at the bottom left is the only button that creates the tag.
Thank you very much if someone can help me !
