Hello there
When I’m developing design solutions I often have the case that I want to design variants of interaction patterns used for a design problem. Now I’m copying the whole page or duplicate a state in a dynamic panel and do the change on the copy for the alternative solution(s). The problem here is that if something other changes that all the variants have in common I have to change it on all the variants, I was looking at the adaptive view and the master views. Re adaptive view I’ve read that it is not possible to make changes in the interactions settings without affecting the other views. So this is not solving my problem. And in the master views you can’t break apart only widgets that would change in the different variants.
Any ideas how my problem can be solved?
Thanks
Best regards
Ricci
