CSS body question
Hi all
I’ve built a page and have it centered. When I look at the html, there are 2 body tags. The second tag has a CSS property of position: relative. This is causing problems with something else I’m doing - a datepicker that uses a Jquery library where the calendar that appears ends up in the wrong place on the screen.
The only way I can get it working is to override the CSS with a plugin and set it to position: static.
This seems to do the trick but I don’t know if there are other implications from doing this.
Any ideas?
