Hi Ezra!
This expression will give you that.
set text on whatever to [[Now.addDays(-1).getMonthName()]] [[Now.addDays(-1).getDate()]], [[Now.addDays(-1).getFullYear()]]
If you want just the first three letters of the month:
set text on whatever to [[Now.addDays(-1).getMonthName().substr(0,3)]] [[Now.addDays(-1).getDate()]], [[Now.addDays(-1).getFullYear()]]
The second one takes an absurd amount of parsing, because you have to convert a string like “Pacific Standard Time” to “PST” - but the following works. It’s easiest with two commands. The first extracts “Pacific Standard Time” or whatever from the result of the keyword Now, and the second converts that string to its acronym and pre-pends the other stuff (removing the seconds from the time). Note: you can find out how all of these string functions work by googling their javascript equivalents. Target.text gives you the existing text of the object whose text you are setting.
set text on whatever to [[Now.substring(Now.indexOf(’(’)+1, Now.indexOf(’)’))]]
set text on whatever to [[Now.toLocaleTimeString().substr(0,Now.toLocaleTimeString().lastIndexOf(’:’))]] [[Now.toLocaleTimeString().slice(-2)]] [[Target.text.substr(0,1)]][[Target.text.substr(Target.text.indexOf(’ ‘)+1,1)]][[Target.text.substr(Target.text.lastIndexOf(’ ')+1,1)]]
