I’ve been playing around with various datepickers suggested in the forum but struggled to get one that was simple and worked how I wanted it to. Just playing with something I found on the Jquery site:
I’ve put this in a plugin just called jquery
<script>
<link rel="stylesheet" href="//code.jquery.com/ui/1.12.1/themes/base/jquery-ui.css">
<link rel="stylesheet" href="/resources/demos/style.css">
<script src="https://code.jquery.com/jquery-1.12.4.js"></script>
<script src="https://code.jquery.com/ui/1.12.1/jquery-ui.js"></script>
<script>
$( function() {
$("#u213_input").datepicker({
dateFormat: 'DD, d MM, yy',
</script>
</script>
Then just added a text field on the page.
The only thing you then have to do is find out the id of the text field and make it match with where I have #u213_input.
(I don’t know if there’s a way to avoid this step? If it’s part of a bigger form and you change anything then you might have to redo this bit if the id changes)
Oh, and set the date format as you want to see it.
Works a treat!
