Hi, I need some help debugging the following two issues:
I have set up a counter that adds/subtracts 1 in order to count the number of selections made. It sometimes adds/subtracts 2 and I can’t identify the case.
To reproduce simply try clicking on the checkbox. There are some combinations of clicking clear all/done that adds/subtracts 1 but this isn’t always the case.
Note: the actions need to stay on the group and not moved to the checkbox widget please. -
The size of the dropdown should change dynamically. If the user has made a selection it should reflected “## selected” and resized to fit that + an ‘x’ appears. If the user clears/unselects the selection it should default back to “Input placeholder” and resized to fit that.
I previously had this set up to resize with a fixed number based on the known width of “## selected” however I’d like to make it more dynamic to allow more flexibility with the string used for reflection.
Any help identifying the issues and/or potential solutions would be much appreciated.
Referenced file:
Filters_Filter-Dropdown.rp (72.1 KB)
