Delete rows interaction not working in Axure cloud
This is the code: [[Item.ID==’05’]]
It’s working perfectly fine locally, but when I checked in Axure cloud, the row with ID ‘05’ won’t delete. Please help!
There was a bug with curly quotes not being recognised in repeater logic. They may not have updated the renderer on Axure Cloud to fix that bug yet. If you’re on a Mac, go into System Preferences and select Keyboard > Text, then untick ‘Use smart quotes and dashes’. Then retype your logic. The quote marks around 05 should not appear ‘curly’ once you’ve done that and it should work on Axure Share.
That works! Thanks a lot Man!
