Im kinda stuck.
I made a Dynamic panel with different states (article pages).
On one state - page - there is an accordion menu.
In the accordion menu, one item there is a link to load more text via a different state (click or tab and then set panel state).
So what does happen is that the more text is shown, after closing the menu its reset to short) text - good. When the accordion is opened, its back to the short text - good, but the link to show the long text, does not work the second time…
This action only works once… why???
In the console I see the function is being called/fired… nothing happens…
I tried to change the link into a button or a hot spot or place it outside the dynamic panel. All off this resulted in only changing the state once and then its dead…
If I close the accordion item with the link before I click on the more text option, is closes - good, opens and the the link is dead aswell…
So im thinking its not the link/button/hot spot… its the ‘code’… but I do not what to do so it will work.
— attachment removed —
Please help me!!!
Thanks in advance!
