I have a series of dropdowns that are placed in a dynamic panel and master. For some reason these do not work. When I click to open the dropdown menu they are not working at all. Any ideas?
Dropdown not working
davegoodman
#2
If you have set up click/tap interactions on the whole dynamic panel that the dropdown is within, then you won’t be able to click on the elements inside, as the dynamic panel will ‘capture’ the click.
Try removing any interactions you’ve set on the dynamic panel and see if you can click the dropdowns.
